- Nov 14, 2005
- 1,431
- 0
- 76
These past few days my computer has grown extremely loud and hot, I cleaned the dust out and check if all the fans where running.
All of them worked including the video card fan.
I am not sure exactly what the cause of this random jump was as I have neither overclocked or change anything in my computer. According to my temp display on my case I am reading 80 degrees Fahrenheit and before all this happened my computer was displaying around 64 on full load.
To prevent the computer from really going overboard I have a fan cooling the side of my open case (not sure if that?s a good idea, but that?s what I?m doing)
Either way even with that on it seems at least my video card is extremely hot and Everest is noting 47 degrees on my GPU and 43 ambient, 51 for the CPU and 38 for the motherboard.
Anybody might have any ideas? Or a way to fix it without having to pay any money?
(I just blew all my money on books for school and I?m broke, so it will be a while before I can buy anything.)
Something at least temporarily?
And in the future what would you recommend I do/buy?
I am running on a P4 550 with HT @ 3.4Ghz with stock HSF
Gigabyte 7800GTX
2 gigs of corsair value ram DDR2 533
915 P Combo-FR (flashed to latest version if that helps any)
600W Okia PSU (I know it?s ******)
thanks in advance for any help
Gigabyte 7800GTX
