Hey All!,
I've been having a problem with an AMD setup using a Gigabyte Mobo with a VIA KT400 Chipset. The CPU is an 2000+ (about 10 months old)
I've got an Enermax 431 watt PS
About 6 weeks ago, the CPU suddenly started getting much hotter on average... around the 49-51C range just sitting idle. Previously it had been around the 40C range. Also, I'm using a ThermalTake Volcano 7 and it was doing around 40C with the fan on low setting... now the fan is set to the high setting (~6500RPM) and it's still only keeping the chip down to about 50C. If it gets very warm in the house and the air conditioning isn't on, the CPU will hit above 60C and start to destabalize the computer after only 10-15 minutes of work. Most of the time it seem's perfectly stable (even for game play) in the 50-55C range.
I was goofing around with Motherboard Monitor this morning and noticed something really strange. My voltages are as follows:
+3.3 = 3.31
+5.00 = 4.93
-5.00 = ZERO!
+12.00 = 12.52
-12.00 = -7.68 and bounces to -6.82!!!
Is it possible that the PS is actually putting out these voltages? Could the computer actually continue to run like that? If so, could this be the cause of the CPU overheating? If the computer couldn't actually run like that, then is the sensor probably whacked on the mobo?
Help?
Joe
+3.3 = 3.31
+5.00 = 4.93
-5.00 = ZERO!
+12.00 = 12.52
Help?
Joe
