- Dec 11, 2000
- 12,273
- 4
- 81
Well on my way to work today i was sitting in traffic and thank goodness i looked down and saw the temp gauge raising to H. I quickily pulled over and popped the hood to make sure i had fluid in there. I had not been using the AC btw. There was fluid in the resevoir and after waiting a few, there was fluid in the radiator. Some lawnmower guys were nearby and suggested that I crank the heat when i started it again and that might "reset the sensor". When i started the car, the needle started moving up, so i cranked the heat. It stopped rising and dropped back to about 1/3 (close to the cooler than the hot). On my way to work i left the heat on for a minute then stopped it, it stayed 1/3 the whole way to work.
My question is, WTF happened? I had fluid in there, was the sensor being stupid? I wasnt sitting in traffic for that long and its only 65F outside here. Thanks SOOOO much for any thoughts.
