overheated parts - need replacing
superjohnyo
257
My friends computer just overheated. He said that he has some software to control all of his fans; evidently the software screwed up and stopped all of his fans. I'm helping him replace his comp and wanted to get these parts checked out. Let me know if you see something bad.
He has his AGP Sapphire x800xt still, the fan didn't stop on that. He also has 1.25GB of pc3200.
Mainboard: ASUS A8V DELUXE
http://www.newegg.com/Product/Product.asp?Item=N82E16813131510
Processor: AMD Athlon 64 3700+ San Diego
http://www.newegg.com/Product/Product.asp?Item=N82E16819103539
Hard drive: Seagate Barracuda 7200.8 ST3250823AS 250GB
http://www.newegg.com/Product/Product.asp?Item=N82E16822148065
Power Supply: Fortron Source AX500-A ATX12V 500W
http://www.newegg.com/Product/Product.asp?Item=N82E16817104934
Case: Thermaltake XaserV WinGo V7000D
http://www.newegg.com/Product/Product.asp?Item=N82E16811133131
DVD Burner: NEC ND-3540A Black
http://www.newegg.com/Product/Product.asp?Item=N82E16827152047
Any problems?
AdamSnow
5,736
Why not just replace the chip?
That's about the only thing that would die from the fans stopping... the Motherboard is *probably* okay... hard drive, power supply, DVD-Burner, Video card, etc. will all still be just fine...
CraigRT
31,440
what happens when you try to power the PC on after the overheat?
if absolutely nothing happens, then the mobo may have died.... but if it powers up and beeps, might just be a CPU as stated above.
I cant see why more than 1 of those parts would have gone bad.
superjohnyo
257
I'm just going by what he said. I think he was about to upgrade anyway, so this is a good excuse.
Mar 10, 2005
14,647
Yup. I'll add, it's not a great idea to buy an AGP mobo nowadays.
raildogg
12,892
572
well you can get an Asrock 939 pin motherboard that supports both agp and pci-e so you'll be future proof. everything else looks fine
if he wants to upgrade, then thats one thing, but make sure all the components are really fried.
