Overclocking XP1600+ up to XP2100+, any problems?
gwlam12
6,946
Anyone have a problem overclocking from XP1600 to an XP2100? At first, everything seems okay. Temps are at 53C, but when I run 3dmark2001 SE, my pc locks up in both XP2000 and XP2100. I have not yet tried running 3dMark2001 at XP1900. Everything is stable until I use my video card too much. It's not my video card because things are fine at XP1600+. Any recs?
Boonesmi
14,448
how are you overclocking? fsb? multiplier?
what motherboard?
what voltage do you have the vcore and dimms set for?
gwlam12
6,946
hi. abe helped me, i forget his username here.
i upped my fsb to 164. motherboard is msik7t266. voltage is at 1.8. dimms are at default.
abe and i concluded that i need a new motherboard since pci and agp cant run at 164 . something like that.
Mangler
633
yeah you don't have the correct divider, plus it sounds like your heatsink is not of good quality. Better leave it be till you can buy a better mobo, and HSF
Rafael
868
Hey Gary!
Nice OC! :)
I think the problem is not overheating, since U got a Volcano 7+ there.
What happens when U run 3DMark, n other benchies? BSODs? Or it just go back to ur desktop? Or it freezes?
Maybe up a little bit the vdimm will help you.
Thinking about getting a new mobo? Heheheheheheheheheheehhehehe Probably now that the KT400 r comin out the KT333 will drop the prices.
Good luck on ur OC!
Raf
gwlam12
6,946
Volcano 7+ running at 3200RPM. I think that's a good HSF. Better be. Cost me 30 bucks. :)
Rafael...might not get a new mobo, even though you predicted it. :) I'm running at XP1900+. I think it should be fine now, haven't run 3dMark yet. But a jump from XP1900+ to XP2100+ won't be that noticeable for me.
Rafael
868
Hey Gary!
I think the Volcano 7+ is a good HSF too. Whats the fan setting? Lowest speed?
Yeah u probably fine running @ 1900+, wont even notice the difference on real applications.
Raf
SHoddyCOmp
2,072
I am having no problems whatsoever getting my 1600 to 2100 speeds. I think i can go higher but i dont want to "really" push it quite yet ;)
My setup
XP 1600+ AGOIA F 0212
EPoX 8k5a3+ (With voltage issues (Not the PS)... :( << That btw are temps with my room door closed, stock 1600+)
Corsair XMS PC2700 (Dang, I really want some genuine samsung 3000 or something :) oh well)
Volcano 9
VERY stable running Prime95. Its running at just a few C higher than when my room door is closed at stock speed. I have my room door open so that my room has got some cross ventilation, otherwise it turns into a sauna. lol. So really its running a bit hotter but its running stable as a rock. Later tonight I will run 3dmark 2001 at the same time and loop the tests for a while and see what that does to it. So far though despite the voltage extreme abnormailties it is functioning quite well.
Curently under 100% load it is running at:
42c CPU
29c CASE
mamisano
2,045
Just installed my AGOIA "Y" chip today too....from Newegg.
Specs:
Epox 8K3A+
XP1600 AGOGIA "F" @ 2100+, 1.75v
Crucial PC2100 @ PC2700, 2.8v - "FAST" bios settings
Alpha PAL8045 w/35cfm fan: Idle: 48c Load: ~52c
Radeon 8500-64 Retail @ 300/300
2x WD 100MB JB (No Raid)
SB Live Value
No problems just yet. I am waiting for some $$$ to come through so I can buy a real case/PS and some PC2700 or better Ram.
dannybin1742
2,335
AGOIA xp1600+ @ 1743mhz (166X10.5) @default voltage
water cooled by maze3
epox 8k3a w/antec true power 480
256mb genuine samsung pc2700 2.7volts 2.5 2-5-2 1T
via on chip diode 32idle 38load (actual temp)
Insane3D
19,446
My setup
Volcano 9
42c CPU
29c CASE
What voltage issues? Your voltages look fine, with the exception of your +12v being a little low, but within limits... I've got two 8K5A2+'s here and they both have extremely stable voltage regulation...
