Overclocking XMS 3200 LL ram, need help
dxkj
11,772
ok I have it at
2 2 2 5 @ 200mhz right now, stock voltage running great
Has anyone overclocked this at agressive settings and had any luck? I did 2 2 2 5 @ 201 stock voltage and couldnt even boot
chizow
9,537
I could run any non-3D stress stably at cas 2-5-2-2-1T up to 210MHz at 2.7V, anything higher required me to relax timings ot 2-6-2-2. Didn't test the theoretical max though, as my 9700pro/A7N8XD refused to do any 3D over 195MHz, so I didn't see a point. Running at 190MHz 2-5-2-2-1T now at 2.6V. Just an FYI, going over 2.7V voids your warranty with Corsair.
Chiz
chizow
9,537
Originally posted by: dxkj
my bios allows me to do 2.63 and 2.77, is 2.77 ok or nay?
I would post in the HoH forums and address it specifically to Ram Guy. That's the official Corsair tech support forum and is moderated by a Corsair Rep who answers questions specifically (as well as direct RMAs and such). Before voiding your warranty I would apprise him of your situation and what his advice would be. Its worth poking around in there a bit as well if you are a new Corsair XMS owner. There's 5 or 6 diff. Corsair forums there, a bit light on substance/traffic, but still worth a read thru for a general overview of issues.
Chiz
techfuzz
3,107
Do not go higher than 2.8v, your warranty will be voided. This is straight from Corsair's tech support at the HoH forums. I run my XMS PC3200 at 2.8v without any problems. Just make sure your case is well ventilated and circulates air properly.
techfuzz
dxkj
11,772
Thanks guys, it runs smooth as heck at 200 2225 when im at 2.77 volts but not at 2.63, My case has a total of 8 fans (well 1 of them is on the processor)
thanks
