Hi, I have an E660 on a P5N32-E Plus. stock is 2.4 and I have got it up to 2.8 with no real issue, but I'm having problems getting over that.
I've noticed that regardless of the voltage I type into the mobo once I've restarteed it and its loaded the voltage to the vcore is always different to what I typed in.
so at 320FSB on a multiplier of 9 I type in 1.34 and it wont load, if I reduce it to 1.3 it loads but the voltage to the vcore if I check it on voltage levels is actually 1.42. If I type in 1.42 on same settings it won't load.
Any ideas?
The bios at moment is stock, I'm going to update it this week as I can't at moment.
Any ideas?
