Overclocking using Detornator 12.81 drivers
Stumps
Doe anybody Know how to unlock the Detornator 12.81 drivers for overclocking?
I have tried the "CoolBits" registary tweak and it will display the Clock frequency tab but you can't use i,
Does anybody know how to fix this?
Did you check the "Allow clock frequency adjustments" checkbox at the top? You need to do that before you can adjust the sliders.
If you did, and it still doesn't work, or if the box is greyed out, you'll need powerstrip or a similar too. Ask someone else where to get it, I have no idea.
Yep, but when it restarts the "Calcamalator" the box is uchecked and the sliders are greyed out.
I think it could be a driver conflict that isn't showing up in the device manager of 98SE, because when I tried to use an older Detonator3 driver that I could overclock with the samething happened.
It's been about a year and 3 videocards,2 motherboards and 3 cpu's since I formatted my drive maybe it needs doing real bad
Get Rivatuner at Guru3d. Click on the little grey triangle that's on the Main tab then; that brings up some more tweaking options including a clock control window.
