Overclocking the Monitor. Get 70hz. heres how!
Status
Not open for further replies.
tweakboy
9,517
www.hammiestudios.com
I did this many times, It should work if your monitor is a good one.
Mine the monitor actually says 70hz ,, not 60hz like LCDs are.
Already UT3 was smooth movement now its feels like a CRT.
Vsync ON ,
If you wanna do this or to do it and see if your monitor will take it.
Launch nVidia panel. go to custom resolutions. and change the 60 to a 70hz
Worked for me, Worked for my dads LED, Didnt work on old 2ms LG ..
ViRGE
Elite Member, Moderator Emeritus
167
This isn't the right forum for this, TB. It belongs in Video.
Status
