Overclocking system parts(Ti4200)?
Brackus2
48
Hey everyone,
Just upgraded finally from thunderbird1.1 to a system with:
2500+ 256pc400 asrock K7S41GX with my same vid card: Ti4200 with vivo found at the link below:
http://www.leadtek.com/3d_graphic/winfast_a280_letd_myvivo_1.html
VGA Memory Clock 445.5 MHz
VGA Core Clock 249.8 MHz
it is running at stock clocks and My system runs at 43celcius, 48celcius system temp, the vid card looks like it has nice cooling and fan on it but I dont want it to burn itself out either.
Can I and how can I overclock this gpu? will it make a dif on my system especially if I am looking at playing most if not all new games for 2004? what clock should I am for with this card?
Thanks for replies,
Dustin
Jan 31, 2002
40,819
If you're playing "most of the new 2004 games" you'll quite simply need a more powerful card.
However, the video card right now is probably the last thing you should worry about. I don't know how the hell you can stand to run XP on 256MB. :p Buy another stick of 256MB at LEAST, and overclock that 2500+ to 3200+ speeds.
- M4H
Delorian
590
- M4H
Exactly right, that'll give you a huge boost, after that if you still want to overclock the GF4 Ti then use power strip and be very careful. To tell if the card is getting to hot use an "artifact tester" which you can find freely on your favorite search engine.
Jan 31, 2002
40,819
- M4H
Coolbits is free, smaller, and is already installed. :p
- M4H
beatle
5,661
I'd say it's worth it. I know I'm getting significantly more mileage out of my 64mb Ti4200 because it's clocked @ 300/625.
Actaeon
8,657
20
Originally posted by: carlosd
Ti 4200 is still alive!! Yeahh!!
Ti200 for life! ;)
Stuck in a 2.2ghz Athlon rig.... eh. :(
Ordered a 6800GT, hopefully it arrives soon!
Delorian
590
- M4H
- M4H
Haven't tried it yet but I'm sure I will eventually. OP you should check into this one.
Brackus2
48
my cpu is now running at 1846mhz, and im eager to see what this vid card can do, my cpu is running at 52celc, and mobo 42celc. my room is pretty hot though around 30.
Anyway, it looks like a good heatsink/fan combo, and my clocks are fairly low, I might even be able to achieve past 4400 speeds shouldnt I?
Anyway, I dont want to ruin this vid card, but I would like to try what it can take.
Is there just some program I can run? i have the latest drivers from nvidia.com and win xp...
thanks for any help!
Dustin
