overclocking problems
Motorway
Hello to everyone, this is my first post here. I have a problem with my system I built. Specs are....
Asus k8v
3200+
ati 9800 pro
1Gb pc3200 Ocz ram enhanced latency twin sticks of 512mb
2-seagate 120 GB serial ata drives in raid 0
Xp home with sp1
bios version 1005
420 watt power supply
The ram is set to auto and is in the 1 and 2 slots. This is the problem....I loaded xp everything was fine...I set bios from normal to standard..went fine..set to turbo mode and just as soon as the via raid bios came up I recieved an error that my array was broke and was unable to boot back into windows. I had to reformat and repair the array.....Then I decided to leave it at standard and try moving the fsb up along with cpu voltages and mem voltages leaving the clock multi. alone, when I got it to 215mhz windows would not boot and said I had a system/config file corruption.. Why would overclocking cause my array to crash? I even tried running one harddrive and no array with no help. Does anybody have any ideas. Memory compatibility?Junk motherboard?I have had many asus motherboards in the past without any troubles.
Anybody have any ideas. Any help would be appreciated.
