Specs:
AMD A64 3000 Venice core
MSI K8N NEO2 PLAT.
OCZ 520W PSU
OCZ 2x512 VX GOLD PC3200
The problem I am having is this:
I started overclocking my cpu, I decreased the HT from 4x to 3x, lowered my ram divider from 200mhz to 100mhz and proceeded to increase my htt. (I got up to 290x9=~2556 mhz) and I found that it was stable running prime95 for about half an hour. I liked these results and decided to stop at this point.
Next I began to try to overclock my ram by doing the following. I left the ht at 3x, raised my divider back to 200mhz and started increasing my htt, by 5 until I reached 224. This is the highest htt i could reach and run memtest without failures.
Realizing the above I decided to use various memory dividers to try to maximize my overclock, but for some reason anytime that I would use 166 (and try to get htt higher than ~250) or use 133 (and try to get htt higher than ~270) I would not be able to post. My ram has to run under ~180mhz even though it is ocz vx gold. I have posted on other forums with this and had no useful help offered. The only thing I was told was my motherboard was crap.
I should add that my mobo has been flashed to 1.8 (best from what ive read) and I am using a CALIBRATED ddr booster (pushing 3.2v without any ram cooling)
Basically I need information on one of 2 things. 1. Is there anything I can do to get my ram to run a little better and be able to get a better overclock.
and
2. If the above is not possible which of the following 2 settings would you guys recommend me to use:
a) 270htt x 9 = ~2450 [133 ram divider]
or
b) 290htt x 9 = ~2556 [100 ram divider]
I am currently using A.
Thanks in advance.
MSI K8N NEO2 PLAT.
OCZ 520W PSU
and
or
Thanks in advance.
