engineereeyore
So I have the following:
MSI K8N Neo4 Platinum motherboard
AMD Athlon 64 3200+ Venice core
2x512MB OCZ EL Platinum DDR400 Ram
Thermaltake 430W power supply
Thermaltake Venus 80mm fan/heatsink
I can't seem to get the processor overclocked any higher than 2.3GHz. I'm using a 230 FSB, 4X HT multiplier. Ram is set to 180/200, so reads around 207. However, this is as high as I can put it. If I try to increase to 240 or even 235, the computer won't boot. The temperature has never, even under load, gone over 42 degrees, so I don't think it's temperature. The motherboard is supposed to be one of the best overclocking motherboards on the market, so I can't believe it's the motherboard. My best guess is that I'm not getting enough power. According to bios readings, the power seems pretty stable and close on all voltages, but I can never check it after increasing the FSB.
I've tried increasing the FSB to 300 and changing the cpu multiplier to 8x, and ram to 133/200, which would be back to 200. This doesn't work either.
If anyone has any ideas, please help.
