- Jul 20, 2004
- 706
- 1
- 81
Hi all,
First off, let me tell you what hardware I'm using:
Intel Core2Duo E6400
P35-DS3R motherboard
2x2GB G.Skill RAM (cheap)
700W OCZ Stealth X-Stream PSU
GTX 280
I recently encountered an odd problem while trying to re-overclock my CPU.
A couple of months ago I was able to run my CPU at about 2.9GHz OCCT stable (24hrs). I was having some trouble with my computer, and to minimize possible causes I set my CPU back to default settings. The problem ended up being my hard drive, but I didn't remember to re-overclock my CPU.
Since this happened, I've made several changes to my computer:
Upgraded my 8800GS to current card, GTX 280
Upgraded my Antec TruPower 500 to current PSU, 700W OCZ
Upgraded Windows XP to Windows 7
Installed additional hard drives
I realized that I wasn't overclocked anymore, so I decided to go back into the BIOS and change my frequency back to what it used to be. It starts up for about 3-5 seconds with the new clock speed after I save the settings, then restarts and changes the CPU clock to default. Even if I try to increase the CPU clock by 1MHz it does this.
What is the most likely cause? Am I stupid and just forgetting some small detail about overclocking? I'm going crazy here. I used to have such a nice overclock!
Thanks for any help,
jz
GTX 280
jz
