Overclocking on msi k7t pro 2a?
Feskhau
4
Anyone had any problems with it? I've tried many times now, and I've used at least 5 different pencils. I also tried cold soldering tin, and still no result. When I adjust the multiplier the Mhz goes down, and I have no clue why. BTW, I have a duron 800.
Please help me!
dirkdaring
Banned
Jun 7, 2000
249
You must be crossing the L1 bridges when you do the pencil trick. I did it last night on my Pro2a with a Duron700, worked on the first try. I used a high quality HB lead for my mechanical pencil (I'm a graphic designer, have a ton of the lead around). Try again, be very careful not to join the side bridges together.
Dirk
DragonFire
I got my Thunderbird 1Ghz working fine at 1150MHz using a #2 pencil.....the only overclocking problem I had was increasing the FSB, the highest I could get was 110Mhz any higher and my AGP bus was to high for my video card....
Feskhau
4
Hmm, gotta give it another try then. Try a different pencil then, again, lol. Last time I used 0.5 HB pencil-pen, thought that should work. Should I try an ordinary pencil?
Thx for the input btw
Dec 14, 2000
80
Hello,
I used a mechcanical pencil, worked the first try.
Those lines are dang small..
try the find the smallest lead in width, it'll make crossing them abit easier.
