How good is the NV performance tool? it can check the disk, graphics, memory and overall specs of youe system, 3 days ago everything looked just fine but since yesterday, my PC is like freezing 3 seconds, when I open a explorer window, it freezes a little bit and then pops up, when I control panel, the same thing and the nv performance test sometimes hit as low as 32 in "write" when the baseline of that program is 100 !! I dont know what it is but I want my PC to run as It should be and to be stable, here I send u my configuration and times maybe you can help me please.
Asus A8N SLI premium
AMD 64 San Diego 3700+
OCZ Dual Channel 1GB PC3200 EL Platinum Rev 2
Evga Geforce 6800GS CO superclocked (490/1100 out of the box)
Hitachi Desktar T7K250
Antec TP II 550w EPS 12v PSU
Centurion 5 case
Here are my times:
Dram Configuration:
Timing Mode: Manual
Memclock index value: 400 mhz
Cas latency (TCL) : 2.5
Min ras active time (TRAS) : 7
Ras to Cas delay (TRCD) : 3
Row precharge time (TRP) : 3
Row Cycle time (TRC) : 16
Row refresh cycle time (TRFC) :22
Read-to-write time (TRWT) : 3
Write recovery time (TWR) : 3
1T/2T memory timing : 1
S/W Dram over 4gb remapping : Disabled
H/W Dram over 4gb remapping : Disabled
Hyper transport frequency : 3
Amd K8 Cool'nQuiet : Disabled
Jumperfree Configuration:
Overclock profile: Manual
CPU frequency : 250
PCI Express : 100mhz
DDR voltage : 2.8
Chipset voltage : 1.6
HT voltage : 1.25
CPU multiplier : 10.5 (or whatever the max is on your cpu)
CPU voltage : 1.550
PCI clock syncronization mode : 33.33mhz
The CPU is running at 2.641 and the memory 1048.74
The GPU at 500/1200
Please help maybe im doing something wrong!!!
Centurion 5 case
Here are my times:
Dram Configuration:
Timing Mode: Manual
CPU frequency : 250
DDR voltage : 2.8
HT voltage : 1.25
CPU voltage : 1.550
The GPU at 500/1200
