The BIOS isn't always as clear as that.
You should be able to manually set your memory to 200/166/133/100 MHz, which is for PC3200/PC2700/PC2100/PC1600, respectively. However, when you raise the system bus, these frequencies don't always hold.
To get your Venice to 2.4 GHz, you'll have your system bus running at 267 MHz. If you keep your memory setting at "200 MHz," its actual speed will be 267 MHz (which will toast your DIMMs). If you set it at "166 MHz," its actual speed will be 222 MHz (which may or may not be stable). To help with stability, try easing up your timings. If you can't get it stable at 222 MHz, go ahead and set it to "133 MHz," which will yield a real speed of 178 MHz. You're memory may be slower, but the performance gain from your high CPU clock will more than make up for it. Plus, at 178 MHz, you can probably tighten up your timings and still run stable.
