- Apr 19, 2008
- 200
- 3
- 45
I'm overclocking my E8400 after getting my vendetta recently. I have clocked it to 3.4 ghz with great stability, but 3.5 crashed playing Crysis after 10 minutes and 3.6 ghz would not load windows, but posted. I have my mobo auto selecting the voltages, but manually lowered the memory freq. to under the stock 800mhz for a 1:1 ratio. My cpu and gpu temps are all good. I'm guessing I may have to manually set the voltages which are autoset to 1.2v for the cpu and 2.08 v for the memory when at 3.4 ghz. Perhaps my memory is a tad weak for stressing. Any thoughts to increase my overclock? Thanks.
My system:
E8400 cpu with vendetta cooler (with push pins still) at 3.4 ghz, 1.2v
gigabyte ga-p35-ds3l mobo
4 gig ocz vista upgrade memory at 5-6-6-18 at 800mhz stock ddr2 1.87v not overclocked and 2.08 overclocked
msi 8800 gt OC 512 memory
HDD WD 250 gig with 16mg cache
case coolermaster centurion mid tower
windows vista 32 bit
My system:
