Overclocking my E7200--> Current settings in OP.
MentalIlness
2,383
11
First off, I have read the sticky on this subject, and to be honest...while a lot of it makes sense to me, a lot of it don't.
I know these E7200 CPU's overclock really well, and I have been running at 2.53 ever since it was purchased.
My hardware:
E7200 "CPU-Z says M0.....Everest Ultimate says C0"
http://www.newegg.com/Product/Produc...82E16819115052
Cooler Master Hyper 212 "2 x 120 mm fans / push..pull config"
http://www.coolermaster-usa.com/product.php?category_id=1623&product_id=2731
OCZ 850 "4 x +12 rails / 20 Amp each"
http://www.ocztechnology.com/produc...rmance/ocz-gamexstream-850w-power-supply.html
Gigabyte UD3P
http://www.newegg.com/Product/Produc...82E16813128358
4 GIG DDR2 800
http://www.newegg.com/Product/Produc...82E16820231122
Settings as of right now
PHP:
CPU Host Clock Control --------------- : [Enabled]
CPU Multiplier ------------------------: 9.5
CPU Host Frequency (Mhz) --------------: [266]
PCI Express Frequency (Mhz) ---------- : [100]
C.I.A.2 ------------------------------ : [Disabled]
CPU Clock Drive ---------------------- : 700mv
PCI Express Clock Drive -------------- : 700mv
CPU Clock Skew (ps) ------------------ : 0ps
MCH Clock Skew (ps) ------------------ : 0ps
DRAM Performance Control
Performance Enhance ------------------ : [Standard]
Extreme Memory Profile --- (X.M.P.) -- : [Disabled]
(G)MCH Frequency Latch --------------- : [Auto]
System Memory Multiplier ------------- : [3.00A]
Memory Frequency (Mhz) --------------- : [800]
DRAM Timing Selectable --------------- : [Manual]
Standard Timing Control
CAS Latency Time -------- 5 ---------- : [5]
tRCD -------------------- 5 ---------- : [5]
tRP --------------------- 5 ---------- : [5]
tRAS ------------------- 15 ---------- : [15]
Advanced Timing Control
tRRD -------------------- 3 ---------- : [Auto]
tWTR -------------------- 3 ---------- : [Auto]
tWR --------------------- 6 ---------- : [Auto]
tRFC ------------------- 52 ---------- : [Auto]
tRTP -------------------- 3 ---------- : [Auto]
Command Rate (CMD) ------ 0 ---------- : [Auto]
Channel A
Static tRead Value ------------------- : [5]
tRD Phase0 Adjustment ---------------- : [Auto]
tRD Phase1 Adjustment ---------------- : [Auto]
tRD Phase2 Adjustment ---------------- : [Auto]
tRD Phase3 Adjustment ---------------- : [Auto]
Trd2rd(Different Rank) --------------- : [Auto]
Twr2wr(Different Rank) --------------- : [Auto]
Twr2rd(Different Rank) --------------- : [Auto]
Trd2wr(Same/Diff Rank) --------------- : [Auto]
Dimm1 Clock Skew Control ------------- : [Auto]  ps
Dimm2 Clock Skew Control ------------- : [Auto]  ps
Channel B
Load-Line Calibration ---------------- : [Disabled]
CPU Vcore --------------- 1.1000  ---- : [1.10000]
CPU Termination --------- 1.200V* ---- : [1.200v]
CPU PLL ----------------- 1.500V* ---- : [1.500v]
CPU Reference ----------- 0.755V* ---- : [Auto]
CPU Reference2 ---------- 0.800V* ---- : [Auto]
MCH/ICH
MCH Core ---------------- 1.100V ----- : [1.100]
MCH Reference ----------- 0.800V ----- : [Auto]
MCH/DRAM Ref ------------ 0.900V  ---- : [Auto]
ICH I/O ----------------- 1.500V ----- : [1.500]
ICH Core ---------------- 1.100V ----- : [1.100]
DRAM
DRAM Voltage ------------ 1.800V ----- : [1.90]
DRAM Termination -------- 0.900V ----- : [Auto]
Channel A Reference ----- 0.900V ----- : [Auto]
Channel B Reference ----- 0.900V ----- : [Auto]
Advanced Settings
Limit CPUID Max. to 3 ---------------- : [Disabled]
No-Execute Memory Protect ------------ : [Enabled]
CPU Enhanced Halt (C1E) -------------- : [Disabled]
C2/C2E State Support ----------------- : [Disabled]
x C4/C4E State Support --------------- : [Disabled]
CPU Thermal Monitor 2 (TM2) ---------- : [Enabled]
CPU EIST Function  ------------------- : [Disabled]
Virtualization Technology ------------ : [Disabled]
Integrated Peripherals
Legacy USB Storage Detect  ----------- : [Disabled]
edplayer
2,186
What do you want to run it at?
I recommend something like 3200 or so. To do that set your CPU Host Frequency to 400MHz and CPU Clock Ratio to 8. CPU vCore can be set to Auto but that will likely give it more voltage than it needs (something like 1.3XX I think). You can set that to 1.10 or 1.15
MentalIlness
2,383
11
I know some of them hit 4GHZ....but I would be completely happy with at least 3.6GHZ. Which these seem to do well on air cooling.
edplayer
2,186
set the CPU Clock Ratio to 9 (cpu host freq still at 400MHz). You will need more cpu voltage. 1.3 should work and if it does, I would start try lower amounts (maybe dropping by .025V every time). Or you could just try it at 1.25V (might even work with it lower)
Also you will have to change your System Memory Multiplier to get your ram to work at 400MHz (its rated frequency). That BIOS is a little confusing but you want a 1:1 ratio. Don't remember which choice it was (A, B, C, or D)
MentalIlness
2,383
11
Ok, I fell asleep last night, and never got to do this.
So going to start now, oh, and should I change my memory voltage ? If it is even needed.
MentalIlness
2,383
11
Thanks happy, was wondering about that.
Anyone here with a E7200......"if you overclocked it" please post your hardware and settings.
I'm trying to get the most out of this CPU for the next few months. Then I will finally upgrade.
Ok, I am heading to the BIOS now.
MentalIlness
2,383
11
Ok, I'm in the BIOS, and the M.I.T settings are "grayed out" and is non-selectable.
Why ?
I have never been in this BIOS until now.
So how do I ENABLE the M.I.T settings ?
Supersonic64
372
Since your cooling seems good enough, I'd give it max volts (1.36250) and max NB (1.3) and try 4.0GHz. Then work your way back from there until you get stable at the highest possible frequency and then work on getting the volts down.
MentalIlness
2,383
11
How is this for cooling ? :)
Oh, and the option to "ENABLE" host control.....is grayed out. Non-selectable. Why is that ?
TridenT
16,800
45
Your vcore is really low for some reason...
Anyway, 1.325-1.35v @ 9.5x375mhz works for me. It gets you at 3.56Ghz and is stable for me. Temps are reasonable for my setup. I don't try to push the 400mhz because it requires a lot more vcore just for an extra 200mhz.
MentalIlness
2,383
11
Yes, I noticed that too. Ive had this CPU for about a year now. And it has been that low on voltage ever since day one of installing it.
Never "EVER" had a problem with it either. :)
Oh, and the screeny says case opened.....But it is "not" opened. The side panel is on. P182 case.
VirtualLarry
56,587
10,227
Yes sir. And it does absolutely nothing :(
It enables hidden options on Gigabyte BIOSes. You have to hit it at the main menu screen (listing each of the sections of the BIOS), and then navigate to where the advanced CPU settings are, and more things should open up to you.
edplayer
2,186
from that picture I see "Advanced Clock Control" greyed out and that is correct. It is a title and the options are underneath so it there is nothing to select (on that line).
under "Standard Clock Control" you want to select CPU Host Clock Control and set that to enabled. That will allow you to change the front side bus (FSB). There are lots of different ways you can set it up but I would start by setting to to the 400x9 like posted above (to get 3600MHz). The 9 you select in CPU Clock Ratio (already set) and set Fine CPU Clock ratio to 0.
as for your voltage, it looks fine. I have a Q9550 and its VID is 1.25. It is not one of the better ones. I have seen some Q9550 at 1.10 VID. Those (quad cores) are usually higher than dual cores like your cpu so your 1.076 is good. If you want to do 3600MHz, that 1.3V range is probably more than you will need. With a good cpu it should be able to do that in the 1.2~1.25V range. Try 1.25V I recommended use a 9 and 0 multiplier (versus 9 and 5 like you have stock and Trident posted) because you can get a higher FSB getting you more performance. You can go even higher on the FSB (maybe 500MHz or even more) but that would require more tweaking and 400 should be easy without any changes.
MentalIlness
2,383
11
Yes, you are correct. However......I "cannot" select CPU Host Clock Control to "enable" it. The only thing on that screen that I can select, is what is highlighted in red.
I cannot select anything above Advanced Clock Control.
MentalIlness
2,383
11
Well, I fixed it. Removed the battery for a few minutes, then put it back. Booted into Windows with one stick in slot 1....then booted into Windows with the other stick in slot 1.
Everything in the BIOS is now able to be changed. No idea how it came to be like...."read only"
