Hello all,
This is the first overclock I have done in a long time.
I have a E6300 rev L2, a Gigabyte 965P-S3 (rev1, I believe) with Bios F4, and 2GB of Cosair CM2X1024-6400 DDR2.
I have just tried some mild overclocks and I get the same result. I change my CPU frequency, adjust my memory ratio to 1:1, and manually set my vcore to 1.3250. I boot, the computer runs fine. I reboot, and I sit there at a black screen and the fans are running. Nothing comes up on the screen. Then I have to open up the case, clear the CMOS, and it boots with corrupted CMOS, which I then set back to the defaults and everything works normally.
Today, I even ran Orthos for over 4 hours with no errors. I noticed after the first clearing of my cmos, it nows reports my Tjunction as 85c, which it was 100c. Here is a screen shot.Screen Shot
The only thing I can think of is to update the BIOS. Any ideas?
Thanks!
Thanks!
