I installed XP x64 back at the end of november, right after it came out. It went great, and I had zero issues, other than the lack of daemon tools support and ATI WDM drivers. It ran rock stable at my current overclocked 3000+, running at 2.55GHz, 1.45V vcore. All of a sudden, last week, it stopped working. Whenever i try to start winXP x64, the windows boot screen pops up, then just reboots. No message, no nothing. I dropped back my OC to 2.45GHz, and it successfully booted, and I even ran Prime95 stable overnight. But then the next day, when I booted, it would boot up, but then restarted within a few minutes, once again with no message. Due to the prime95 stability, it doesn't seem like a OCing issue.
So i figured maybe the SATA drive was getting corrupted; i've heard that with very high FSB speeds, SATA ports 1 and 2 can cause corrupted drives because their locks don't work right. Well, i had it plugged in to 3 and then 4, so that didn't seem like an issue. Clockgen also reported my PCIe clock to be fixed at 100MHz. So i tried installing XP 32-bit on the same drive, with the 2.55GHz overclock, and it has yet to crash. It boots just fine. So it's not the hard drive, and apparently the OC isn't causing the problem.
The only thing I can figure is that the AMD64 circuitry is not capable of sustaining an overclock, and that it runs Prime95 stable because it only uses the 32-bit parts of the CPU, which can clock higher. But that doesn't explain why it worked fine for weeks and then all the sudden decided to crap out. Does anyone have a similar situation? How did you fix it?
