- Oct 9, 2015
- 197
- 18
- 81
Hi all.I decided to overclock my CPU i7 2600k sandy bridge to 4.0 ghz and im wondering if voltages on processor are ok,and if my overclock seems to be fine.Also I mentioned I have air coling,not water.I have Zerotherm Nirvana NV120 Premium
My motherboard is asus p8p67 pro rev 3.1 and the setting for overclock :
1.Advanced
-CPU Ratio- 40
-Enhanced Intel Stepside-Disabled
-Intel adaptive thermal monitor-Disabled
-Turbo Mode-Enabled
-Intel Virtualization-Disabled
2.Tweaker
-EPU power-Disabled
-memory freqwency-here I don t now if I let to 1333 or 1600 MHz
-dram timing- ? ? ?
-CPu PLL Voltages 1.800 v ?
3.Load Line calibration
-vram freq -Extreme
-phase control-auto
-Duty control-Extreme
CPU voltage-1.20V, 1.31V-Manual Mode -I wondering if these voltages are OK,or if are high
Dram Voltage-1.509 V
save changes and reset!
Plese tell me if this manual overclocking are fine,if voltage memory are ok and if I need higher memory ram.For the moment I have 1333 MHZ memory
1.Advanced
-CPU Ratio- 40
-Turbo Mode-Enabled
2.Tweaker
-EPU power-Disabled
-dram timing- ? ? ?
-vram freq -Extreme
-phase control-auto
