I have a A64 3000+ Winchester CPU running on an Epox Nforce3 mobo (had to, still AGP), with 4x512MB of Hyper-X memory(2GB total). I was able to bring my FSB to 250 with a HTT of 4x. My memory is running at a base of 166MHz, and with this overclock, that's 208MHz. The systems defaults it to 2-3-2-7 2T. My problem is that I can't get this memory to work at 1T. Even if I set the memory to 100MHz base with 2.8V, it still wont boot. It runs fine at the current overclock, but any attempt to run it at 1T instead of 2T causes the system to be unbootable. Any thoughts?
