Overclocking Help
xSnowblindx
101
Ok, a like fifteen minutes ago, i just did my first real overclocking on my Alienware. I made the 2800+ (full specs in sig) run at 2.21ghz or so (200x11). I'm wondering how i know when i've pushed my CPU far enough, and when it's stable still. Also what temperatures should i look for? So what else should i look for in my BIOS?
My RAM is Corsair XMS PC-3200, i'm guessing that i shouldn't touch the settings on that.
My vid card is a GeForece FX 5700 Ultra (128mb), is there any way to overclock a little more performance out of this?
Remember this is all under stock Alienware cooling (couldn't be that bad, right?)
Thanks! :)
imported_whatever
2,019
download and run a program called Prime95. run the "blend" torture test (options -> torture test). if this fails, you need either an increase in vcore or a decrease in clock speed.
also run cpu-z. see what core processor you have. (different cores oc differently). a temperature you should stay below is 60C, that is for the full load temperature.
for the temperature and stability: i mean when prime95 has been running the torture test for 8 hours (although heat will peak in under 1, stability requires at least an 8 hour test).
xSnowblindx
101
Ok, i ran CPU-Z, it's a Barton core.
So i ran Prime95, and after just like 30-40 min, it came up with an error, something about dividing or something? Is this because of my overclock? Arg.
cyberfuzz
427
sure hope you didnt pay over 1k for that system :\ alienware is always a ripoff. and you will need to touch your ram if you want peak performance, you'll want a 1:1 fsb ratio for your ram/proc. so whatever you set your fsb to for your proc you have to do the same for your ram.
GonzoDaGr8
2,183
What is that supposed to mean??
True or not, He asked for help, Not a flaming..:roll:
GonzoDaGr8
2,183
xSnowblindx
You need to look in the BIOS for AGP/PCI divider settings so that you are keeping the AGP @66mhz and PCI slots @33 mhz.. If they are allready, you may have to bump cpu and/or ram voltages a little. Also remember, overclocking is "your mileage may vary". Your proc may not hit as high as you want it too.
xSnowblindx
101
Well i'm hoping that my 2800+ Barton can OC to at least a 3200+ (what it's at now).
So chances are, this was a problem cause by my vcore settings? Right? So i should just up the voltages on my processor slowly until it is stable again?
If this is the case, i probably need to get a motherboard monitor to see if my cpu stays in safe heat ranges, right?
Thanks.
Fern
26,907
174
So chances are, this was a problem cause by my vcore settings? Right? So i should just up the voltages on my processor slowly until it is stable again? Yep
If this is the case, i probably need to get a motherboard monitor to see if my cpu stays in safe heat ranges, right? Get it here HERE
Thanks.
xSnowblindx
101
Ok, i upped my vCore settings to ~1.7v, and i'm still getting the error in Prime95: "rounding was 0.5, it was expected to be less than 0.4" or something like that.
What is wrong? ARG!
(still 11x200)
