Hey,
I was messing with OC setting with my i5 2500k. I remember like a year ago, I couldn't find the setting for the CPU base clock, so I turned up the CPU multiplier to something silly like 126 or 136 or something. Needless to say, my computer instantly restarted. Hopefully I didn't damage anything
I recently noticed that my 2500k was running with a ratio of 21 for some reason, so I decided to bump it up to 40. I've done 40 before, and it seemed stable. There were a couple of differences this time, however. Firstly, it seemed to run at 3.7ghz instead of 4.0. This is strange because the last time I bumped it up to 40, it ran at around 4.0ghz (Multiplier was at the default 100). Also, after a bit, I BSOD'd with memory management.
Did I damage my CPU somehow before, which lead to this? Or is it just a matter of inconsistent results, and I would need to bump up the multiplier a bit instead of going just pure CPU ratio?
I would be happy with a 4.0 ghz speed without any voltage changes.
Thanks
Thanks
