Overclocking Hard Drive Help
Mattd46612
670
Whenever I try to achieve high overclocks and end up having to reboot my computer. Alot of the time Ill have a windows registry error and I end up having to reinstall windows and lower the clock. What is the reason for this? Is it due to a cheap motherboard? My hard drives are just standard WD or Seagate that you would get at Best Buy.
GML3G0
1,356
Does your motherboard have an AGP/PCI lock? By increasing the HTT, you are increasing the AGP and PCI bus speeds, unless there's a lock. HD is linked through the PCI bus. There is a HTT:AGP:pCI ratio. That's your problem. Either that, or your CPU can't handle it.
Mattd46612
670
Id have to check on the lock. But seeing as this board is about as useless as toilet paper I doubt it.
stevty2889
7,036
8
LOL, I don't know, I don't find toliet paper to be useless. But are you drives SATA or PATA?
n7
21,281
4
Your SATA ports are obviously not locked...IOW, i wouldn't OC.
Unfortunately, alot of the earlier mobos with SATA don't have locks, which means OCing = no go.
Mattd46612
670
I have my 2600+ running near 2.1 If im right. But I always figured osmething was wrong because I would go near 2.3-2.5 and it would go to windows, I would get a error, reboot and my registry would be destroyed. When I get this new mobo/cpu Im going to make sure I OC it safe and right. Just concerned the Geil ram will hold me up.
n7
21,281
4
Ah i didn't even notice you were the same poster, duh.
What RAM is that? PC2700?
