overclocking gpu fps with kombuster, fps drop?
khusang
Hey guys, just started ocing my msi 560ti 448. I've done some light reading on the subject, and I'm using the msi afterburner/kombuster that came with the cd.
I heard that ocing video cards don't bring much noticeable gaming benefits(correct me if i'm wrong), so I'll probably just see what I can get out of the card on stock voltage.
I got the card to go from 750 - 890 before i get an error message about nvidia display drivers not connecting to something.... Is this a voltage issue?
I also noticed that if I run kombuster (1080P, full screen, xtreme burn-in, no AA, everything else default) at the default 750 clock, I get 52 fps, but when i bump it to 800mhz the fps drops to 42? Should i be concerned about this? I only ran it for 10 mins, everything else seemed fine.
thanks for the reply. What should I be using instead of Kom/Furmark? I've heard of people getting the the same card from 750 to 950/1000mhz core, which I assume makes a a noticeable difference in games.
fwiw, i'll be playing witcher 2 on a 23 inch monitor @ 1920x1080.
