Originally posted by: Minotar
Originally posted by: Gamingphreek
You are making this more complicated than it needs to be.
HKEY/Localmachine/Software/Nvidia Corporation/Global/NVTweak
Then in the NVTweak folder create a DWORD value labeled "Coolbits" with a hex value of 1.
That enable Coolbits 1.0 (Not sure the manual way for 2.0).
Do that or download the XG drivers.
-Kevin
No I am not making this more complicated than it is! If I was, I would have had a decent response days ago instead of going through this fiasco
Here is the problem I have with your instructions you just blurted out so quickly....
1). You don't have a Geforce 6X or 7X series video card
2). You don't have an SLI setup
3). Your coolbits value of "1", I have never ever seen listed anywhere
So, why should I go with what you say? My rig is very specific and your settings definately do not apply to mine. Please read the entire post before you go blurting out instructions that may or may not apply. Thanks.
