Overclocking Asus A7N8X Deluxe(Need Help)
Hub1
19
I have a slight problem
I was overclocking my comp and the comp shut down while starting a benchmark test. When it restarted I didn't have any video. Now I cant go in and change the bios back without seeing anything. Is there anyway of getting the bios changed? Or did my video card go out on me? Or am I just S.O.L.
thanks for the input
Asus A7N8X Deluxe
Barton 2500
Geforce 3ti200
Crucial 512MB PC 2700 DDR RAM
Antec SX1040BII
kalex2
61
Have you flashed your cmos since the black screen. That will reset the board for you
AnonymouseUser
9,943
107
Yes, clear your CMOS (see your manual for instructions) and try again. That will reset the BIOS to the default settings. If that doesn't help, you may have fried something.
