Hi everyone..
i have an older system with the following specs:
Motherboard: Gigabyte GA-965P-DQ6 (Bios: F13A)
CPU: Intel Core 2 Duo E6600 (2.4GHz)
RAM:
Storage: Adaptec RAID 4805SAS 8-lane PCIe controller
i read that overclocking this particular CPU to 3GHz is quite simple and reliable, so i tried raising the Host Frequency from 266 to 333Mhz and increasing the voltages in steps.. but all the settings from the lowest voltage to the highest voltage resulted in either of the following symptoms:
1- the system would boot up, and show the CPU speed of 3Ghz, but would reboot directly after showing the RAM capacity and drop the host frequency to 266 and multiplier to 6 (1.6Ghz)
2- the system wont boot up at all.. it reboots 2-3 times and reverts the settings back.
i'm attaching two screen shots of my bios related to the CPU and overclocking settings..
everything is pretty much set back to default now, but the screenshots would help show those unfamiliar with this particular motherboard and bios what options are available to get the job done.
i know the default cooling setup may not be adequate, but i just wanted to find out the settings the system would run at, and then maybe invest in a cooling mod.. otherwise give up on the whole thing.
from what i read, many people with this CPU and Motherboard combination have had good success with overclocking.. so what am i missing?
One more thing..
now that i started looking through overclocking settings, etc.. i noticed that at the normal operating conditions, and while the PC is basically idle.. the system temp is ~44*C (expected considering there are 6 HDDs inside the case) but the CPU core temp is ~74*C!
i think that's quite high for this type of CPU.. i checked the fan and it's clean and running at 2000+RPM, and the heat sink is properly seated..
so i enabled C1E and TM2 which dropped the core clock speed to ~1.6Ghz when idle, and that in turn reduced the temperature to around 55*C
is this normal? if not, could this be causing my system to run sluggish (which is why i started looking into overclocking in the first place)?
Could this CPU be busted?
any help would be REALLY appreciated!
RAM:
- Kingmax KLDD48F-A8KB5 PC2-6400 1GB
- Kingmax KLDE88F-B8KU5 PC2-6400 2GB
RAM JEDEC timings table (CL-tRCD-tRP-tRAS-tRC @ frequency):
- JEDEC #1 3.0-3-3-9-12 @ 200 Mhz
- JEDEC #2 4.0-4-4-12-16 @ 266 Mhz
- JEDEC #3 5.0-5-5-18-23 @ 400 Mhz
One more thing..
