ibex333
Hello guys. I already asked about this some time ago, but back then, I simply couldnt understand all those overclocking guides, so I had to give up...
Since then I did a lot more reading and researching, and finally I felt confident to try again.
This time, I think I got something going here, and I need your help.
Many people here told me I can get up to 2.6GHz on stock cooling, but it seems that is very far from the truth in my case. I was only able to get to 235HTT with 10multi and vcore at 1.50v. Any higher HTT and CPU craps out and reboots, during startup.
So then I pushed the vcore to 1.55v and was able to get to 240HTT with 10multi. This seems to be my absolute max, and I am reluctant to go any higher since my temps flirt with 54c at this point. (on full load with prime95 of course) Otherwise, around 45c
Do you think that if I raise my HTT any higher the temps will get above 55c?
Since I have trouble understanding how to overclock RAM, I decided not to do this for now, and settled at 166 (DRAM/FSB : 5/06) This puts my RAM at 199MHz which I guess is fine... However, when I click on the memory tab in "Cpuz", it shows that my memory is set to 2T. I guess that what my mobo did since I have it set to auto... When I set it to 1T in BIOS, my PC wont POST. What gives?
Some screenies I think you should see
Anyway, do you think I can do anything to go even higher with my stock HSF?
Any advice is greatly appreciated.
PS:
Also if you know any links that explain memory dividers and how to select them according to FSB + how to overclock ram please drop me a couple since I just cant understand this stuff... I need something like a "complete idiots guide". 🙂
PPS:
Right now my memory is running in single channel mode because the guy who was helping me build my PC set it up like this. Some people here told me to put it in DIMM 2 and 4 to get dual channel. If I will do that, will that screw up my CPU OC in any way?
(sorry for a newb question)
PS:
PPS:
