episodic
Hi, I have a Duron Applebred 1800 processor. I have the bios set at 145/36 now yielding a 1957 mhz overclock (stock is 1800).
The motherboard is an ASUS A7V8X-X
I have not messed with VCORE yet, not sure if I want to risk it or not.
I have DDR 2100 Ram Kingston.
If I increase the CAS latency from 2.5 to 3, I can go farther in my FSB adjustments, correct?
To be absolutely 'safe' what is the max you'd do if you were me? Temps are 42c now, and it seems stable (ran through Prime 95 for a while)
Here are my Prime95 benches for those interested. . .
AMD Duron(TM)
CPU speed: 1957.10 MHz
CPU features: RDTSC, CMOV, PREFETCH, MMX, SSE
L1 cache size: 64 KB
L2 cache size: 64 KB
L1 cache line size: 64 bytes
L2 cache line size: 64 bytes
L1 TLBS: 32
L2 TLBS: 256
Prime95 version 23.8, RdtscTiming=1
Best time for 384K FFT length: 42.378 ms.
Best time for 448K FFT length: 50.325 ms.
Best time for 512K FFT length: 54.079 ms.
Best time for 640K FFT length: 72.093 ms.
Best time for 768K FFT length: 90.475 ms.
Best time for 896K FFT length: 113.615 ms.
Best time for 1024K FFT length: 144.627 ms.
Best time for 1280K FFT length: 199.954 ms.
Best time for 1536K FFT length: 239.269 ms.
Best time for 1792K FFT length: 287.619 ms.
Best time for 2048K FFT length: 329.104 ms.
AMD Duron(TM)
L1 TLBS: 32
L2 TLBS: 256
