imported_Kan
hello people,
hoping you guys can help this newbie 😀
i just bought a X700 Pro 256MB and was wondering if it's worth overclocking?
if someone has done it, is the improvement noticeable? or shouldn't even bother?
and which OC program do you use for that?
since the X700Pro has no temp monitor like the XT series... any recommendation to keep an eye on the temp? or anything should take into consideration?
thanks a lot
thanks a lot
