- Jul 18, 2003
- 12,651
- 1,514
- 126
Pertinent system specs:
ASUS P5W HD Deluxe, 975X chipset
8GB A-DATA DDR2 800
Q9550@3.0Ghz currently, Link to Intel's Online specs.
Zalman 9500 CPU HSF unit
PC Power & Cooling 610w Silencer (49A single 12V rail)
I would like to take my Q9550 to 3.4Ghz or 8.5x400Mhz FSB. I can get 353Mhz on the RAM with 1.90V easily for the 3.0Ghz overclock; every other voltage is stock. Heat produced by the CPU is about 50°C and 38°C for the NB with all four cores fully loaded with 4xFolding@Home instances running. I set the memory to DDR2 600 to make sure the memory wasn't flaking out at DDR2 800 speeds with only 1.9V, so this isn't the problem. Tried 400Mhz FSB with 2x2GB also and overclock failed, so I'm not convinced that the MCH is flaking out due to too much memory being installed (although voltage suggestions would be appreciated here too).
I'm thinking of increasing the VID voltage of the CPU to 1.3V and taking the memory to 2.0V just for good measure to try and achieve 3.4Ghz. Any suggestions on a starting point for NB, SB, etc. voltages as a starting point? Speedstep and CPU fan throttling are disabled. Also, any other suggestions to achieve this overclock are appreciated.
I've read through the OC guide on this forum, but I would love some people's actual settings for their Quad 9450 or 9550 setups that are 3.4Ghz or better. Thanks in advance for any comments left.
8GB A-DATA DDR2 800
