overclocking a 9500PRO
hi, ive been looking for a site that reviews a Connect 3D Radeon 9500PRO (which is the card im running) and cannot find one. the reason is i wanna know how far i can OC it. the core is the same as the 9700 and that runs 325Mhz is it possible that i can go that high?
the memory is 3.3 ns Infineon Made DDR ram, its current clock is 270Mhz. as with most ATI cards there is no cooling at all on the memory chips.
the specs --- Core is 275Mhz, memory is 270mhz (540 effective)
with 3.3ns ram does anyone have any idea hoave far i can push this baby?
i have had 315 on the core and 306 on the memory and with these settings i ran both 3D marks (01 and 03) a couple of times and it was ok.
i then played UT2k3 but that then crashed after bout 1hour nd a Half im guessing it was either the card or the fact that i had two overclocking applications running and they may of been conflicting.
any ideas?
thanx
I believe the 3.3 is rated for 303MHz. The core should definitely go higher than 315, and I recently saw an article which said that O/C the core has a greater effect than O/C the memory. Just use Radclocker for O/C. It adds an overclocking tab to your display settings.
