- Dec 11, 2006
- 204
- 0
- 71
Hi Guys,
This forum has been my biggest motivator and educator in the field of OC Science .
thanks to all for the wonderfull and truth filled figures of OCed specs, i did not believed in the first place but now i can say C2D chips are built for OCing ...
my System config.....
E6300 @ 2.8 gigs and vcore at 1.425 volts
RAM transcend 667 mhz JM338888Q664433A--6 @ 800mhz, volt 2.1
CPU FSB 267 @ 400mhz volts MCP-- 1.3v
i have achieved this with Stocked Coolers and 3 fans. !!!!!!
down goes the pics for the same..
http://img330.imageshack.us/img330/2859/cpucorevoltagehy8.jpg ------ CPU Core Voltage
http://img359.imageshack.us/img359/1444/cpuinfohz5.png ---- CPU info
http://img355.imageshack.us/img355/8870/meminfovr6.png ---- memory info
http://img431.imageshack.us/img431/7626/moboinfocw0.png ----- MOBO info
http://img252.imageshack.us/img252/4065/ntunetj2.png ---- ntune settings
http://img363.imageshack.us/img363/4296/ntune1ah5.png ----- ntune bios settings
http://img461.imageshack.us/img461/8310/nvidiamonitor1jp9.png ------ nvidia CPU monitor info
looking at the pics you can notice one thing, that the core temp for CPU is running at 66deg
i do not know whether it can cause any problem or not, if u guys suggest me to revert back then i will do so ??
the system temp is at 30deg and the GPU is at 47deg
the most amazing thing is that my RAM is OCing like hell, i never expected it to run in that manner, looks like i got one hell of a RAM here
link to the Mem spec http://www.jetram.com.tw/product/Pdf/JM388Q643A-6_2345.pdf
if you guys notice my MOBO info pic it states that i am using nforce 590i series but i am not...
my MOBO is BFG nvidia nforce 680i SLI, i dont know why it is showing that info??.
well i think i achieved something today by OCing my system for the first time and i have all ready put my system on stress test using Prime95.
and one more thing my previous vague tries (say around two times i tried with some guessed settings --- remember that i am novice in here ) have failed miserably. only today it started working.
i would like to know if anything is wrong in here and if so then i will revert back..
thanks in advance..
thanks in advance..
