I'm having some issues with my overclocking process. I'm kinda new to it but have read a lot about overclocking the C2D's. I built the pc this weekend and immediately changed just the FSB to 400 and everything worked fine - ran Prime for 24 hours with no errors. I am in the process of trying to get to 4GHz but when changing the FSB to 410 it wont get pased the post and I need to clear the CMOS to get back into BIOS. I tried changing the cpu voltage but I still get stuck trying to post. I've also played with the memory voltage but that also fails. I've set the timings to 5-5-5-15 and tried them at auto - neither result helped. I'm thinking that I'm close but need some guidance as what to look at next to help get the post to complete. I can post a pic of the post later today but it see's the CPU and sees the 4G of memory but it doesn't seem to understand what kind of memory it is (if that makes sense).
Also is there a good read on when to change voltages or when not too - and when the north/south voltages might need to be changed?
Thanks,
Jer
Thanks,
Jer
