Oh and if you need to test the stability of the o/c, try RTHDRIBL. If your card passes several hours of RTHDRIBL torture you've got a good overclock going on.
Yes it just enables the registry settings that nvidia built into the software but disabled on install. Here ya go. I don't think it has a selective overclock ability though.
Honestly I use RivaTuner. It is a lot more specific in what you tweak, at least I think it is. Coolbits does a good job to, but I like the versatility of RivaTuner.
Hi! Not to threadjack, but I am thinking about getting some more juice out of my 6800 vanilla. I currently have a Dell XPS Gen4 with a 6800 256MB PCIe card that came with it. I've never overclocked a videocard before and am a little hesitant. I'd like to get a bit more juice in my Half-Life 2 and Counter-Strike: Source games. I downloaded and installed Coolbits 2.0 this morning from Guru3D and it says my card is currently running 325/600 for the GPU/mem. I had it detect the optimal settings and it came up with 422/796! Is this what my card is capable of or is this a bit extreme? Are those speeds safe? I'm anxious to hit apply, but I don't want to burn my card up!
I have stock cooling on there right now and my card is idling around 54C with the ambient reporting 41C. I'm thinking about picking up the NV Silencer 5 (please correct me if this is wrong) for my card before I overclock. Is there any significant danger I could encounter in the long-run from overclocking?
By the way, is this the right cooler for my series of card? (6800 vanilla PCIe)
