so today I decided to overclock my 3570k because I finally had the free time to do so. I'm not going for a huge overclock I just wanted about 4.2 ghz or so so i went into the bios on my asrock extreme4 z77 and upped the multiplier, I didn't mess with any of the voltages because I just wanted to see if it would be stable on "auto" it booted fine and I ran prime95 small FFT for about 3 hours or so, I topped out at about 82* C on the hottest core with my h100 and voltages were around 1.17 volts which is probably kind of high for 4.2 ghz but I was going to try and mess around some more to get the lowest voltage and still a stable clock. so after about 3 hours of prime i decided that should be good since no tests had failed and temps were good. I know some of you guys like to go longer than that but im impatient lol. so after prime I let the cpu cool down for about 10 minutes or so and then decided to jump into a game of BF3 for some in game testing. everything went well for about 45 minutes then the game crashed and blue screened me. so I restarted, set everything back to stock and went into bf3 again for about 2 hours, no problems what so ever. so I thought i might try my luck again, maybe it was just something weird. so i set the multiplier up to 42 again, voltage at auto and everything else untouched, i played for around 3 hours with no hiccups and no blue screens. so I was wondering, should I test further? up the voltage? or could it be a ram issue? I would automatically say its ram but since it has worked for a month straight with vigerous gaming and testing at stock settings why would it just fault now?
thank you for any help you can give me
