Overclock advice
darkeyed
Currently cpu is at 10x230 1.41V
Memory is at 1:1 at 2-2-3-8 1T V2.80
HTT at 4X
I havnt done any long term testing at that but it is prime95 stable for over 30 minutes.
I have run memtest for one complete pass and solid at above settings which is really cool.
I had a problem with fsb at 225 untill i bumbed my vcore to 1.41. Now I am testing at fsb=230.
I have a few questions.
First off - which SATA ports are locked? I think it might be 5-8 and my hard drive is on 1.
Does PCI-E have a lock as well? How does the fsb effect a PCI-E vedio card?
If memtest passes is that reliable method of checking ram? If prime95 fails what do most people back off first?
Any other ideas?
Thanks
OK well Sandra runs fine through benchmarks but prime95 fails again at fsb of 230. Memtest passes fine so just not sure what to tweek. I would like to get around 240 or 250 if I can. I am impressed with this memory though.
HTT at 4X
Any other ideas?
Thanks
I think it might be SATA 1-4 because they are with nforce4, SATA 5-8 are wih SIL3114.
You can change PCI-E freq. in BIOS, but default is 100 MHz
Ok
I thought it was 5-8 because that is running off the pci buss.
So if I leave the PCI-E freq at 100 it shouldnt cause me a problem? Although I have a ati 800XL and it doesnt seem as fast as it should. I ran some priliminary numbers off 3dmark and it was in the mid 4000 range. I dont have it in front of me. So I need to see whats up with that as well.
