Over voltage setting on Mobos?
BoboKatt
Hi there,
Is there any difference on stability with either using the over voltage option on most mobos OR actually dialling in the start-up vcore voltage? When I OC I just keep using the overvolatge like 2.5% or 4% or 5% 8% and so on... does this make any difference on performance? Most mobos I have used when you actually dial in the desired voltage for the CPU it's NEVER that when you read it from software (mind you most monitoring apps are not accurate).
