Hi,
Not sure if anybody here has done any outside coax wiring on their homes before, but if you have, you might be able to help me.
We just bought a home and moved in. I'm trying to re-configure the wiring so that I can get my three "inputs" running in harmony: cable modem service, DirecTV and VHF/UHF antenna (for HD local signals).
Right now, the cable modem is wired as such:
Direct line from the community cable box to the local box on the back of the house.
Line hits a standard grounding block, and then follows to a 2-way splitter.
One split line (we'll call this Out-A) goes directly to the cable modem in our "office."
One split line (we'll call this Out-B) goes down to the basement where it is split a further 3 times, each running to a room in the house.
So here' what I want to do:
Run the cable modem line directly to the grounding block, eliminating the splitter.
Run the over-the-air antenna line directly to the interior splitter in the basement (with a second grounding block).
And here's the problem:
The minute I disconnect the Out-B line (see above), the cable modem (on Out-A) stops working.
*OR*
The minute I remove the splitter and connect the cable modem line directly, the cable modem stops working.
As soon as I put the splitter back in, with both Out-A and Out-B connected, the modem picks right up again and I'm back on.
Does anybody know why this would be occuring? Or have any suggestions as to what I need to put on the line to get the modem working again, *without* using the splitter?
Thanks!
*OR*
Thanks!
