Outlook problem
domsq
243
Hey guys
I have a weird problem with my PC currently. While I'm busy compiling an email, Outlook will sometimes just automatically send the message before I've even finished typing it!
Needless to say, this is rather frustrating. I don't have any viruses\spyware, so what the heck could be causing it? :confused:
randomint
Banned
Sep 16, 2006
693
damn this must suck. is it a particular combination of keys you are pressing? Alt+S sends out the message. is your ALT key busted? depressed permanently.
in the meanwhile, don't type in the sender's address until AFTER you're done typing the message completely.
amheck
1,712
Good advice. I had problems with Outlook several years ago and switched to Mozilla Thunderbird and couldn't be happier.
corkyg
Elite Member | Peripherals
27,370
240
Open Tools, and Options, and uncheck SEND MAIL IMMEDIATELY WHEN CONNECTED.
domsq
243
Sorry for the thread resurrection, but I worked out what the problem actually was... my hand was brushing my laptop's touchpad, when the cursor happened to be sitting on or near the 'Send' button :p
