Outlook Help please
skiingliberal
90
Hoe do I transfer all of my old contacts/ emails from one computer to another? Any help would be greatly appreciated.
Thanks in advance.
Vegito
8,329
express or regular outlook ?
regular outlook you can just make a pst file, copy folder from one pst to another or just copy the original pst..
express is a bit different...
dhoytw
Banned
Dec 10, 2004
655
Thanks in advance.
You will want to export your contacts and messages out of outlook or outlook express. In Outlook you will create a PST file, this is basically a backup file which you can then import the file to another computer. In Outlook Express you will want to create a CSV file for your address book..... it's all very simple actually, if you do a search on google I am sure you can easily find some detailed instructions on how to do this.
