Outlook Email Question -- NEED HELP!!
BlamoHammer
2,259
I am about to format my pc and I was hoping that there is a way to save all of my emails so that I can keep them for safekeeping after the format. Thanks for any help you can provide!!
dakata24
6,366
at least for outlook 2000, goto file --> import and export --> export to a file --> personal folder file (.pst)
Zim Hosein
Super Moderator | Elite Member
65,309
403
PCH0, do a search for a file named outlook.pst, save that file to a CDR or some other removable meida and then after you're done w/ the reformat & you have re-installed Outlook, just click FILE-IMPORT AND EXPORT-IMPORT FROM ANOTHER PROGRAM OR FILE-NEXT-PERSONALY FOLDER FILE (*.PST)-Navigate to where you saved your PST file and click next. Hope this helps :)
BlamoHammer
2,259
Thanks to both of you guys. Will transfer that file over to my backup partition. Much appreciated.
Zim Hosein
65,309
403
You're welcome, see you after the reformat :D
