i basically use the calender in outlook 2003 to keep tabs on life - on calls, appts etc etc.
what i would like to do is be able to set up a simple weekly- recurring form to keep tabs on certain things:
for example i need to keep a log of how many nuclear medicine sessions i attended in a particular week. How can i set the calender up so that i get the entry "number of NM sessions attended" and then be able to simply insert the number for that particular week?
I would have thought a simple recurring appointment wouldnt work since if i insert the number in 1 week it will recur in all the others.
thanks for help!
thanks for help!
