Outlook 2000 Problem
49erinnc
2,095
Have no idea where it disappeared to (or how) but when I view my Inbox, I'm only seeing the name of the person the email came from and the size of the message/file. It had always shown the date/time received as well but for some reason, it doesn't show it now. I have toggled through all the tools/options and for the life of me, I can't find where you display the info I'm missing. I'm sure it's right under my nose but I can't figure it out.
Can anyone lend a hand here? Thanks!
sixone
25,030
61
Go to View ->Current View->Customize. I forget what the first menu choice is, but there you can add/remove what you want displayed. Hope this helps.
49erinnc
2,095
Thank you so much sixone...that was the fix. I had toggled through to "Current View" previously but I thought the "View Timeline" option was my problem but it wasn't. Going into "Customize" and adding "Received" is what I was missing. Just not sure what caused it to disappear in the first place. Oh well...works now. Thanks again!
