out of heat sink compound!!
Jan 9, 2004
110
if I go to radioshack and get the stuff they have will it be fine till I can get more?
I live 3 hrs from phoenix (the only real sorce I know of)
Soulkeeper
6,735
155
he's joking
yeah pick some new thermal paste up
it ain't worth risking it
artic silver 5 is good stuff if you can get that
but the radio shack stuff will work fine (it even drys up slower than most this high performance stuff)
good luck
beatle
5,661
Originally posted by: badaphooko
i heard toothpaste works just as well...
It's true! While it may not last long before breaking down, it'd be nice to use in a pinch while you wait for better stuff to come in the mail.
DAPUNISHER
31,931
32,220
LOL! yeah, that's a famous review alright, but don't forget his disclaimer about using toothpaste
If you think I'm making some sort of guarantee that it won't cause unspeakably awful consequences, though, you're out of your mind. All care, no responsibility.
Actually, not even very much care.
or even that he mentions it's conductive enough to cause problems.
Soulkeeper
6,735
155
i also noticed that the guy in that article used tap water
obviousely the moisture will evaporate in these kinda things that he is using in a few minutes time and his cpu will probably start to die slowly over a few hours or days
that is an interesting test tho
guess artic silver and the other thermal compounds aren't nearly as good as they could be if toothpaste beats them (short term anyways)
Jeff7
41,596
20
Yes, Radio Shack's thermal compound will work. If you want better performance, like if overclocking, Arctic Silver 5 is the new champion, at least where easy application is desired. Otherwise, I think that this is supposed to work even better - but its application is more complicated than Arctic Something X's will be.
