other than the a/c and the fridge, what else consumes the most power?
kreactor
709
my electric bill is like 65$ on avg w/ 2 pc on 24/7
trying to cut down by using flourescent bulbs and lcds
olds
50,125
780
Mines over $275 a month for electric.
Gas is about $50
Sentinel
3,714
prob just be the amount of lights and such. pc? barely notice that, around $2-3 a month
kreactor
709
over has electronic lighter/igniter but is gas powered
methinks the laser in the dvd writer must be the culprit, to amass enough power for the death ray
burn about 50 dvd/month
Colt45
19,720
Originally posted by: Astaroth33
Heh.. my home theater powering up causes the lights to dim briefly..
My home theater causes the whole neighbourhood to brownout ;)
ElFenix
102,402
8,574
how much per kilowatt hour?
newParadigm
3,667
Dude, our electric company is gay, they base your next months pay on the average of the last twelve months, so if you start using a lot less power it take like 6mos for you bill to go down.
Lcd's, get a mobile proc and don't OC it much (keep Voltage down), turn off ac, get all flrouescnat bubls less elec and the last longer, umm microwave?
Open the blinds/shades instaed of using electric light. Get a gas stove/heat. Don't turn the A/C on and off through out the summer, maintain your house at a certain temperature, otherwise the a/c has to work really hard to get it back cool whenever yoru put it on, and you dont save much $$$.
Eli
Super Moderator | Elite Member
8
Actually, our fridge doesen't use very much power at all... And it is an older model. Just the regular kind.. small square freezer on top.
I was quite surprised.
It used about 100kWh a month, or about 8$/mo at our rate of $0.08/kWh.
It draws ~220 watts while running, and 29W while off.
Conversely, my computer draws a minimum of 160kWh/mo.. assuming 100% idle time, which obviously doesen't happen.
15" CRT is 85W.
Mobile AthlonXP/2600+ @ 2.4GHz, 768mb ram, and 5x HDD uses 136W idle and 168W at 100% CPU.
So depending on where you live, it could be anywhere from $10 - 25+/mo... (0.06 - 0.18/kWh), assuming similar computer specs.
vegetation
4,270
Originally posted by: deviant03
I switched from a 24/7 running desktop to a laptop, bill dropped $20.
Makes sense. Laptops usually consume less than 25 watts, including the screen powered up. My HP Centrino 15" laptop only uses 18 watts at idle. Desktop rigs take at least 60-80 watts idling (P4-2.0ghz, integrated grphx, one drive) plus you need power for an external display, of which even an LCD 15" panel would take about 30 watts.
KMurphy
1,014
Maybe when you grow up and start paying the bills; you'll see the advantage of having a near constant electric bill every month. This allows people to budget for the next month and also moderates the cost of peak usage; especially those with electric heat in the winter.
newParadigm
3,667
Umm, yeah, but we went thoruhg our whole house and had energy savers, or some energy company replace windows redo insulation and stuff, cause our electric bill was really high. It ended up dropping by like 30%, but it took a while. Plus we have gas heat. And the only time it would spike is when we turno on the A/c.
Bateluer
27,730
8
65 a month is a cheap electric bill. Ours is 80 something in the winter, 200 something in the summer. Phoenix summers are very toasty.
