Kroze Diamond Member Apr 9, 2001 4,052 1 0 Aug 2, 2006 #1 Did you like the result? I know it comes with 2 weeks in each packet and you should see the difference, but did anyone use it longer than that?
D doze Platinum Member Jul 26, 2005 2,786 0 0 Aug 2, 2006 #2 I tried whitestrips and they helped a little bit, made my teeth feel cleaner too. Kind of expensive though. Curious to see what has worked for others.
Kroze Diamond Member Apr 9, 2001 4,052 1 0 Aug 2, 2006 #3 no luck in using it for like 1 months long hoping to get that sparkling white?
Cdubneeddeal Diamond Member Oct 22, 2003 7,473 3 81 Aug 2, 2006 #4 I tried the Rembrant strips but they made my teeth very sensitive.
